RFXtrx433 remains 'connecting'
I'm trying to get my RFXtrx433XL to work but it seems to fail. I connected an RFX sensor node to /dev/ttyUSB0, after which the node starts connecting, but never becomes connected.
I followed the instructions of the RFX documentation for installing on a Pi, but that manual seems to be outdated (not written for systemd configs).
I would be very happy if someone who has the RFXtrx433xl could help me getting it to work. If I succeed I'll make a tutorial for it.
These are some of my configs:
lsusb
Bus 001 Device 004: ID 0403:6015 Future Technology Devices International, Ltd Bridge(I2C/SPI/UART/FIFO)
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp. SMC9512/9514 USB Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
lsmod
Module Size Used by
cfg80211 525806 0
rfkill 21373 2 cfg80211
ftdi_sio 33030 1
usbserial 29996 4 ftdi_sio
snd_bcm2835 23131 0
snd_pcm 97825 1 snd_bcm2835
snd_timer 22706 1 snd_pcm
snd 68784 3 snd_timer,snd_bcm2835,snd_pcm
bcm2835_gpiomem 3791 0
fixed 3029 0
uio_pdrv_genirq 3718 0
uio 10166 1 uio_pdrv_genirq
ip_tables 12512 0
x_tables 20921 1 ip_tables
ipv6 384532 35
dmesg | grep ftdi
[ 26.396977] usbcore: registered new interface driver ftdi_sio
[ 26.397645] ftdi_sio 1-1.2:1.0: FTDI USB Serial Device converter detected
dmesg | grep tty
[ 0.000000] Kernel command line: bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=18ff364c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.001389] console [tty1] enabled
[ 1.059168] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 26.514890] usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUSB0
cat ser2net.conf
10001:raw:0:/dev/ttyUSB0:38400 8DATABITS NONE 1STOPBIT
Insomniux
You are probably best opening an issue on the nodes github page.
Max (the author) is usually very responsive, but I’m not sure how often he reads the forum.
I have 'answered' this on the github page, with a request for console debug output. I haven't tried an actual physical XL transceiver yet.
Problem solved.
Althought I actually do not understand why, the connecton was established after I disconnected the RFXtrx and reconnected it. Also after reboot the connection to the RFXtrx came up automatically so I assume this problem is solved.
Thanks all for your help
I have seen this type of issue myself - I think it is something to do with the serialport node, which has been through a lot of changes recently, and the dust hasn't quite settled. There will be an update to node-red-contrib-rfxcom/node-rfxcom fairly soon (well, fairly soon-ish) which will use a more recent serialport version, among other things.
