Roon-core node usage (Roon audio server API), any experience?
Hi, i've installed roon-core node via NR palette. This node is supposed to deal with Roon (audio library system) API but no docs about configuration and usage. According to https://www.npmjs.com/package/roon-core this node is a wrapper for the roon node.js API.
Any information ? Regards.
Hi @Herold
I have no experience, but I wouldn't pursue it IMO.
No updates in 4 years, and the author hasn't responded to a 3 year old issue - where there Node was crashing a users Node RED instance
All I can tell you, is that there is an example flow
Hi @marcus-j-davies , thank you for the insight. Any other solution to deal with Roon API ?
Regards
hi, I am the creator of this node. it was indeed built for a specific username involving NEEO remotes. it works perfectly so I didn't change it
You can check in GitHub to fork it if you have any further need.
