Rpm installer script degrades npm [FIXED]
I'm running node-RED in a Oracle Linux VM - Linux v4.14.35 which was installed using this node-RED script.
I updated to NR v1.1.0 a few days ago using the script and wanted to start using the 'https certificate refresh' feature, which required node.js v11+.
The latest version of node.js in the 'nodesource' repo is v10.21.0, so I had to use the Oracle recommended repo and updated to node v12.18.2.
[opc@digitalnut log]$ node -v
v12.18.2
So far so good.
However, ran the installer script again this morning to get NR v1.1.2 and unfortunately the script installed node.js v10.21.0, which in turn stopped the 'https certificate refresh' from working!!
[opc@digitalnut ~]$ node -v
v10.21.0
Should this happen?
The install log shows;
--> Running transaction check
---> Package nodejs.x86_64 0:12.18.2-1.0.1.el7 will be updated
---> Package nodejs.x86_64 2:10.21.0-1nodesource will be an update
--> Finished Dependency Resolution
Dependencies Resolved
 Package      Arch         Version                       Repository        Size
Updating:
 nodejs       x86_64       2:10.21.0-1nodesource         nodesource        20 M
Transaction Summary
ah sorry - haven't updated that in a while - new version pushed that defaults to node12
Working fine now, thanks.
Thanks for spotting it
