"Search" - I'm not getting something
Hey folks.
I am going through replacing a node with another one which is better suited.
I search for it and the list of nodes is show.
To keep things simple, I click on the top one, replace and repeat the search.
Ok. So far so good.
Then this happens.
I've searched for simple and it has pointed me to this function node.
Ok, let's look and see what is happening.
Where is it getting the match for simple?
Can you export that function node and share it here so we can get a proper look at it?
Here it is.
Alas I think I can see what is causing the problem.
[{"id":"12257f9.cd4f78","type":"function","z":"eff5d6e6.236338","name":"MQTT in cheat","func":"var newMsg = msg.payload; \nreturn newMsg;","outputs":1,"noerr":0,"x":380,"y":1470,"wires":[["a18509f4.ec6d58"]],"info":"This node takes the *modified* message and puts it back to what it was on the other machine before it was sent via MQTT.\nSimple.\n2 lines of code."}]
Bottom line.... Kinda obvious.
Sorry for wasting your time.
(Sorry I forgot to "solved" it)
