Search selection
Hi There,
is this possible?
searching for something within a selection. Use case is that I want to search for something but only in a limited set of nodes, not the entire flow.
Checking the dropdown:
I guess the work around would be to copy the selection to a new flow and then search current flow only.
Your workaround actually works today: the search dialog has a "Current Flow" scope (hamburger menu, Search flows, then the down arrow in the dialog), so copy the selection into a scratch flow and search there. A true selection-scoped search does not seem to exist yet. The official editor guide describes the search dialog as indexing the whole workspace, with only the is:config, is:subflow, is:unused, is:invalid and uses: filters. Fun bit of history: an older feature request here asked for current-flow search back in 2018, and the answer years later was exactly that menu option. So extending it to selections is a reasonable next ask, and this thread is in the right place for it.
Hey @gregorius
I've raised Feature: option to limit search to selection · Issue #6033 · node-red/node-red · GitHub to keep track of this
Thanks Nick for picking it up :+1:
I've just commented on it. My choice of prefix is probably erroneous, selection: is probably more appropriate than search: (since the whole context is a search!).
Also I'm for having another search qualifier since then it would be possible to apply the qualifier as part of a direct search, i.e., RED.search.search("only in selection selection:current") which then could be combined to create something rather complex: RED.search.search("only in selection selection:current flow:current type:function") for search only selected function nodes in the current tab.
