Hi! I'm trying to have a flow do a self-deploy with adminAuth credentials. I get the auth token, add the Bearer prefix in the headers, but the GET /flows returns "unauthorized". Does anybody know what I'm missing? Here's the self-deploy code I'm using:
"id": "f03c48f9.385fc8",
"type": "http request",
"z": "7a83f86f.55d4f8",
"name": "POST /flows",
"method": "POST",
"ret": "txt",
"url": "http://localhost:1880/flows",
"tls": "",
"x": 1010,
"y": 660,
"2756ff49.7a67"
"id": "2756ff49.7a67",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"x": 1150,
"y": 660,
"id": "b93f6d0a.9aca3",
"type": "inject",
"topic": "",
"payload": "{}",
"payloadType": "json",
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 230,
"y": 560,
"b96df551.e84528"
"id": "e2cfaaa6.081f68",
"name": "POST /auth/token",
"method": "POST",
"ret": "txt",
"url": "http://localhost:1880/auth/token",
"tls": "",
"x": 570,
"y": 560,
"ec48a95e.ec3ee8"
"id": "b96df551.e84528",
"type": "change",
"rules": [
"t": "set",
"p": "payload.client_id",
"pt": "msg",
"to": "node-red-editor",
"tot": "str"
"t": "set",
"p": "payload.grant_type",
"pt": "msg",
"to": "password",
"tot": "str"
"t": "set",
"p": "payload.scope",
"pt": "msg",
"to": "*",
"tot": "str"
"t": "set",
"p": "payload.username",
"pt": "msg",
"to": "CHANGE_ME!",
"tot": "str"
"t": "set",
"p": "payload.password",
"pt": "msg",
"to": "CHANGE_ME!",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 380,
"y": 560,
"e2cfaaa6.081f68"
"id": "d5b253f4.a73b9",
"type": "change",
"rules": [
"t": "set",
"p": "token",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1040,
"y": 560,
"672dcc9f.b60984"
"id": "ec48a95e.ec3ee8",
"type": "json",
"property": "payload",
"action": "",
"pretty": false,
"x": 730,
"y": 560,
"77702c60.df33e4"
"id": "df2e5d9c.3664a",
"name": "GET /flows",
"method": "GET",
"ret": "txt",
"tls": "",
"x": 630,
"y": 660,
"d8494003.bc263",
"398be1ed.e0ffce"
"id": "672dcc9f.b60984",
"type": "change",
"rules": [
"t": "delete",
"p": "headers",
"pt": "msg"
"t": "set",
"p": "headers.Authorization",
"pt": "msg",
"to": "token.access_token",
"tot": "flow"
"t": "set",
"p": "headers.Node-RED-API-Version",
"pt": "msg",
"to": "v1",
"tot": "str"
"t": "delete",
"p": "statusCode",
"pt": "msg"
"t": "delete",
"p": "filename",
"pt": "msg"
"t": "delete",
"p": "responseUrl",
"pt": "msg"
"t": "delete",
"p": "payload",
"pt": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 440,
"y": 660,
"df2e5d9c.3664a",
"b699581d.56b368"
"id": "b699581d.56b368",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"x": 590,
"y": 700,
"id": "398be1ed.e0ffce",
"type": "change",
"rules": [
"t": "delete",
"p": "headers",
"pt": "msg"
"t": "set",
"pt": "msg",
"tot": "flow"
"t": "set",
"pt": "msg",
"to": "v1",
"tot": "str"
"t": "delete",
"p": "statusCode",
"pt": "msg"
"t": "delete",
"p": "filename",
"pt": "msg"
"t": "delete",
"p": "responseUrl",
"pt": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 820,
"y": 660,
"f03c48f9.385fc8"
"id": "ddff717.ad4279",
"type": "comment",
"name": "Change user/pass below",
"info": "",
"x": 380,
"y": 520,
"id": "d8494003.bc263",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"x": 770,
"y": 700,
"id": "77702c60.df33e4",
"type": "function",
"name": "Bearer",
"func": "msg.payload.access_token = \"Bearer \" + msg.payload.access_token\nreturn msg;",
"outputs": 1,
"noerr": 0,
"x": 870,
"y": 560,
"d5b253f4.a73b9"
) - and it worked fine (once I put my username and password in the first Change node).
