I tried to install sense HAT in node-red but then nothing happened afterwards. I can only see the below:
How did you install it? Also did you see the additional steps required on the node's page - https://flows.nodered.org/node/node-red-node-pi-sense-hat
If you installed via command line then you must restart node-red. If not then try re-starting node-red anyway.
Hi, thanks for the feedback. I managed to install the Sense HAT. just need to search "Sense" and scroll down. ")
