Sensor average function
Looking for solution to count avarage of ‘value’ parameter from this table:
currently have this code but it returns Nan error:
const val = Object.values(msg.payload)
function calculate(array) {
    return array.reduce((a, b) => a + b) / array.length;
msg.payload = calculate(val)
    return array.reduce((a, b) => a + b.value, 0) / array.length;
msg.payload = calculate(msg.payload)
payload is already an array
Works now! Thank you! it returned 245.54500000000002 value, how to round it to 245.5? (found it with SMOOTH node). Thank you for your help!!!
strange, after installation NodeRED Companion (I want to create sensor for average value) it stopped working (NaN error). Even when I uninstalled Node red Companion repository... my current function looks like this:
You have messed up the function. Look again at what E1cid posted.
