Sensor trigger camera issue
Hi
I need help , I have a sensor that triggers camera when value is high but since i get the data by polling every few seconds, it will keep on triggering the camera while sensors are high state. I only want to trigger once then when sensor value is low i would like to capture photo again
Thank you
use the rbe node
Thank you @moebius . It works now. :blush:
