Actually, I am trying to do custom authentication in node-red.
In settings.js file I made change like " adminAuth: require("./user-authentication"), " and created user-authentication.js file created in node-red folder. After that i started node-red, it is showing like " Error loading settings file: /home/devan/.node-red/settings.js "
user-authentication.js -->
module.exports = {
type: "credentials",
users: function(username) {
return new Promise(function(resolve) {
// Do whatever work is needed to check username is a valid
// user.
if(username === "test" && password === "password") {
valid = true;
else
valid = false;
if (valid) {
// Resolve with the user object. It must contain
// properties 'username' and 'permissions'
var user = { username: "admin", permissions: "*" };
resolve(user);
} else {
// Resolve with null to indicate this user does not exist
resolve(null);
authenticate: function(username,password) {
// Do whatever work is needed to validate the username/password
// combination.
if (valid) {
// Resolve with the user object. Equivalent to having
// called users(username);
resolve(user);
} else {
// Resolve with null to indicate the username/password pair
// were not valid.
resolve(null);
default: function() {
// Resolve with the user object for the default user.
// If no default user exists, resolve with null.
resolve({anonymous: true, permissions:"read"});
