Hi Colin!
Doing that it wasn't working for me but after trying so many things, i found one that helps me at least shows me the node and let me use it that int's insç
When i said this:
I started looking for a solution using that, because that usually happens with custom nodes. In the .js code you must change the line module.exports = function(RED) (with "s" the word export) for module.export = function(RED) (with out "s" the word export). I did that and let me use it at least appears in my node-red and i can configure it, i need to try it in the IOT 2000 and in the SD but in my PC i can use it.
Link: Waiting for missing types to be registered - #13 by peret2000
Thank you so much for you help and taking your time trying to help me, i got a lot of knowledges beacause of you!! I'll write here again when i used it if it works.
