Slider control doesn't show balloon
Hello everybody,
on one of my node-red setups the slider show up with a ballon, like this:
grafik
On another system, the ballon with the value doesn't show up:
grafik
The style of both sliders is set to "Auto".
There are no CSS classes set.
After moving the slider, the dot of the "broken" configuration increases in size like this:
grafik
On both systems I'm running v2.2.2
Thank You for every hint!
Are you looking at those two in a browser on one PC or are you using different browsers? If so it may be the browser that is the difference.
Alternatively are you using the same version of node-red-dashboard?
The balloon shows up if your slider is set to output "only on release" and not on "continuously while sliding".
You can have two sliders on the same tab/group, one with the balloon and one without. So it's clearly not related to browser or NR version
I don't know if this is a design decision or a bug.
