Slider doesn't catch the input if just set
Hi, I'm creating the control of curtains, I would like to use the slider also as a switch, pressing nearby 0 or 100 I may have values with differs a bit, so I want round them to 0 (if less than 10 ) or 100 (if more than 90), to do that I'm trying to overwrite the slider value by an input but I see it is catched by Dashboard only if it is delayed for more than 100ms. If I connect the output function directly to slider node the changes won't have affect, so I pass message through delay.
You may consider to fix this in next releases )
