Speed up or disable editor animations
Probably not a popular request, but it should be a pretty easy one. I'd like to be able to either set a speed modifier for all the animations in the editor - opening and closing node settings panes for example - similar to what Android has in the dev options (x0.5, x1.5, etc.) or disable the automations completely. Not because my PC can't handle them, but because it slows me down. I have to actively wait for the animation to finish, despite them lasting only half a second or so.
This may seem trivial to some, but it's comparable to being stuck behind a slow truck. Sometimes you don't mind, but sometimes it just annoys you, which isn't necessary.
This is not currently theme-able - but something that could be looked into.
Short term:
You could adjust or disable transition: "right 0.25s ease" in packages/node_modules/@node-red/editor-client/src/js/ui/tray.js then rebuild node-red, start node-red / refresh browser.
↑ running from src
↓ running from npm installation
find transition: "right 0.25s ease" in red.min.js on your installation and change/delete that, refresh browser.
Actually, this is an accessibility issue as well. For some people, animations can make things unusable.
So I would back a call for being able to turn off all animations in order to make Node-RED more accessible.
