My friends make liberal use of Facebook events, unfortunately I find the events interface impossible to navigate. Luckily they do have a .ics available, unluckily events you haven't accepted are mixed with events you have, so I made a simple flow that splits accepted events from tentative events. This way I can subscribe to this .ics in my Nextcloud instance and give tentative events a different color.
I find a calendar is much more usable.
I used the node-red-contrib-httpauth node. The main bit is contained in a function node, mainly because I couldn't figure out how to sanely do this with the split node.
Use is simple:
- Update the http auth node with your preferred
user:pasword - Add your facebook event calendar url to the http request node
- subscribe to
user:pasword@example.tld/nod-red/facebook/acceptedoruser:pasword@example.tld/nod-red/facebook/tentative
[{"id":"30abd373.bd5524","type":"http in","z":"ce798f74.64a9d8","name":"","url":"/facebook/:request","method":"get","upload":false,"swaggerDoc":"","x":160,"y":300,"wires":[["77e1feab.382658"]]},{"id":"705a7847.bc5d","type":"debug","z":"ce798f74.64a9d8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":430,"y":400,"wires":[]},{"id":"77e1feab.382658","type":"node-red-contrib-httpauth","z":"ce798f74.64a9d8","name":"","file":"","cred":"","authType":"Basic","realm":"","username":"","password":"","hashed":false,"x":240,"y":340,"wires":[["116bd38e.4b7dcc","705a7847.bc5d"]]},{"id":"e1172439.6bf4b8","type":"comment","z":"ce798f74.64a9d8","name":"Secure with Basic Auth","info":"","x":200,"y":380,"wires":[]},{"id":"116bd38e.4b7dcc","type":"switch","z":"ce798f74.64a9d8","name":"","property":"req.params.request","propertyType":"msg","rules":[{"t":"eq","v":"accepted","vt":"str"},{"t":"eq","v":"tentative","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":3,"x":430,"y":300,"wires":[["eaff2195.a68b38"],["eaff2195.a68b38"],["83c3be58.0fc9a8"]]},{"id":"4d794bb0.d8ef74","type":"function","z":"ce798f74.64a9d8","name":"Split Calendar","func":"msg.payload = msg.payload.toString('utf8');\nmsg.payload = msg.payload.replace(\"END:VCALENDAR\", \"\");\nmsg.payload = msg.payload.split(/(?=BEGIN:VEVENT)/g);\nmsg.calendar = msg.payload[0];\n\nmsg.payload.forEach(function(part, index){\n if (part.includes(\"PARTSTAT:ACCEPTED\") && (msg.req.params.request == \"accepted\")){\n msg.calendar += part;\n } else if (part.includes(\"PARTSTAT:TENTATIVE\") && (msg.req.params.request == \"tentative\") ){\n msg.calendar += part;\n }\n});\n\nmsg.calendar += \"END:VCALENDAR\";\nreturn msg;","outputs":2,"noerr":0,"x":1000,"y":300,"wires":[["6b67410a.701ab"],[]]},{"id":"13bdf419.e491ec","type":"http request","z":"ce798f74.64a9d8","name":"","method":"GET","ret":"bin","paytoqs":false,"url":"","tls":"","proxy":"","authType":"","x":830,"y":300,"wires":[["4d794bb0.d8ef74"]]},{"id":"ab19b6e9.4b1ed8","type":"comment","z":"ce798f74.64a9d8","name":"Facebook event calendar URL","info":"","x":890,"y":340,"wires":[]},{"id":"83c3be58.0fc9a8","type":"http response","z":"ce798f74.64a9d8","name":"404","statusCode":"404","headers":{},"x":430,"y":360,"wires":[]},{"id":"6b67410a.701ab","type":"change","z":"ce798f74.64a9d8","name":"","rules":[{"t":"move","p":"calendar","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"headers['content-type']","pt":"msg","to":"text/calendar","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1180,"y":300,"wires":[["d1e9086f.645b78"]]},{"id":"d1e9086f.645b78","type":"http response","z":"ce798f74.64a9d8","name":"Return","statusCode":"200","headers":{},"x":1330,"y":300,"wires":[]},{"id":"eaff2195.a68b38","type":"change","z":"ce798f74.64a9d8","name":"Set Browser User Agent","rules":[{"t":"set","p":"headers.User-Agent","pt":"msg","to":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:73.0) Gecko/20100101 Firefox/73.0","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":630,"y":300,"wires":[["13bdf419.e491ec"]]}]
Hope someone finds this useful.
