Start Up Not Working
Hello, Im having some trubles with the start of node red. Basicaly don´t start. It shows me this error.
I don´t know what happend, yesterday was working fine.
Thanks, Lucas
When did you install node-red-contrib-tedious? And what is it supposed to do?
I don{t know what it its and I don´t remember istalled.
Is your node-red accessible via the internet, or only on your local network?
its in local network
I do not know what that node is either but it's entry on flows.nodered.org describes it as
A Node-red node wrapping tedious.
The tedious node will execute any input given.
If an unknown node with such a sparse and sinister description appeared on my computer I would suspect that I'd been hacked.
tedious is a real thing, see tedious - npm.
" Tedious is a pure-Javascript implementation of the TDS protocol, which is used to interact with instances of Microsoft's SQL Server."
@LucasPeluso I don't understand how you can be using that without knowing that you are doing so.
Regardless of anything else, please do raise a GitHub issue against the node because it should not crash like that with an untrapped error.
Issues · rasmusln/node-red-contrib-tedious (github.com)
I have marked it as 1-star in the flows site due to the crash and lack of meaningful description.
Perhaps I should have said
If an unknown node appeared on my computer I would suspect that I'd been hacked, especially if it has only a one-line description in flows.nodered.org
I see that the node in question has had exactly 1 download in the past week.
But it only has 12 commits, all from a short time period in March/April 2020. Either it does all that the author @rasmusln wants or they abandoned it.
@LucasPeluso, I would strongly suggest that you chose a more popular node if you want to interact with MS SQL.
The error was the node of MS SQL, I will Change it,
What node do you recommend for MSSQL?
I believe that this is the one usually recommended. node-red-contrib-mssql-plus (node) - Node-RED
