I am having issues with losing my connection to a TCP IP barcode scanner on port 51240, It works for a while but then the node shows disconnected. Once i restart the scanner it so far always starts working again for x amount of time. I don't know if its a scanner problem or node-red setup issue.
My next step was to try a different TCP port but I am looking at other ideas on what could be the problem?
I should add I can always ping the IP address
"id": "29bdc5903ebe68f6",
"type": "debug",
"z": "ce6b5df784b18300",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 630,
"y": 1320,
"id": "bd1ad3acab7aa002",
"type": "tcp in",
"server": "client",
"host": "192.168.3.50",
"port": "51240",
"datamode": "stream",
"datatype": "utf8",
"newline": "",
"topic": "",
"base64": false,
"tls": "",
"x": 260,
"y": 1380,
"29bdc5903ebe68f6",
"def1b3201abacdd7"
"id": "897d351c07392aa1",
"type": "inject",
"name": "Trigger Scan",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "T",
"payloadType": "str",
"x": 350,
"y": 1000,
"c177037e93d8721f"
"id": "c177037e93d8721f",
"type": "tcp out",
"port": "51240",
"beserver": "client",
"base64": false,
"end": false,
"tls": "",
"x": 950,
"y": 1040,
"id": "d5e98b7e8b1be7f6",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"x": 630,
"y": 1440,
"id": "c215f2c24b011534",
"type": "inject",
"d": true,
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": ".1",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 110,
"y": 1080,
"05fa8750989cf4a0"
"id": "05fa8750989cf4a0",
"type": "MC Read",
"name": "M500",
"topic": "",
"connection": "8bf9ce709d0bac70",
"address": "M500",
"addressType": "str",
"outputFormat": "1",
"errorHandling": "throw",
"outputs": 1,
"x": 330,
"y": 1080,
"bf36fdbf8698e642"
"id": "0ba908b7db09b02b",
"type": "inject",
"d": true,
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": ".1",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"x": 330,
"y": 900,
"813eb785272c477e"
"id": "813eb785272c477e",
"type": "MC Read",
"name": "Y5",
"topic": "",
"address": "Y5",
"outputs": 1,
"x": 530,
"y": 900,
"bdf70248f339d761"
"id": "bdf70248f339d761",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 710,
"y": 900,
"id": "06b901db64270eaf",
"type": "comment",
"name": "Manual Scanner Trigger",
"info": "",
"x": 320,
"y": 960,
"id": "48d9231513041a71",
"type": "comment",
"name": "Scanner Data",
"info": "",
"x": 250,
"y": 1340,
"id": "7d1f8edd0f0ccc65",
"type": "function",
"name": "If True Return T",
"func": "if(msg.payload == true)\n{\n msg.payload = 'T'\n}\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 640,
"y": 1080,
"c177037e93d8721f"
"id": "20266a9bbd51a1a7",
"type": "comment",
"name": "PLC Scanner Trigger",
"info": "",
"x": 320,
"y": 1040,
"id": "bf36fdbf8698e642",
"type": "rbe",
"func": "rbe",
"gap": "",
"start": "",
"inout": "out",
"septopics": true,
"property": "payload",
"topi": "topic",
"x": 470,
"y": 1080,
"7d1f8edd0f0ccc65"
"id": "8bf9ce709d0bac70",
"type": "MC Protocol Connection",
"name": "PLC1",
"host": "192.168.3.39",
"port": "3001",
"protocol": "UDP",
"frame": "3E",
"plcType": "Q",
"ascii": false,
"PLCStation": "",
"PCStation": "",
"PLCModuleNo": "",
"network": "",
"octalInputOutput": false,
"timeout": "1000"
]type or paste code here
