I have two input nodes:
#1 - catches any incoming message (receiver node)
#2 - catches /help command (command node)
- If you send a random message to the bot, you'll receive an echo message from it
- If you send /help command to the bot, you'll received a help text AND also an echo message. But in this case I only want to send the help message as a reply, withouth that echo message.
Is there an elegant way to prevent sending that echo message, if the original messages was the /help command or any other command.
Thanks.
