Template node "entry" on dashboard
(New project - kinda)
This is a picture of the flow.
See the nodes. Note the one circled in red.
That is the template node.
Screenshot%20from%202019-09-13%2016-21-50
That gives me the background.
Fair enough.
But looking at the screen shot, I have this blank node - shown in red.
Moving the template node around in the list, that blank node moves.
How do I make it invisible?
It is occupying real estate on the screen which I can't afford.
Screenshot%20from%202019-09-13%2016-20-11
Remove it ?
But then I don't have the background picture. So it will work in one way but then remove another option I want.
But if it is invisible, whilst the background picture will be there you wouldn’t be able to see it. How is that any better?
@ukmoose
Could you explain how to make it invisible?
(I know it is going to be obvious, but I am missing it)
Do you mean hide title?
@BartButenaers did you succeed in hiding the context menu, and if so could the same/similar technique be used here? I don’t know too much about the dashboard to answer this myself :slight_smile:
@dceejay did a mod to allow us (internally) set the size of the dashboard entry to -1 so yes but this is not possible at design time (I believe).
I don't think he is in this conversation.
He isn’t, but he had the same issue in another topic.
Luckily I worked out a sneaky way around it by other reasons.
