I would love to use ewelink Node-Red palette that I found but I am getting errors while installing it (installation fails to complete).
Linking the issue that I have opened on the palette GitHub repo:
opened 10:23PM - 30 Jul 22 UTC
Trying to install the palette I am getting an error
2022-07-30T20:54:03.361Z Install : node-red-contrib-shelly 9.4.0
2022-07-30T20:54:03.393Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-shelly@9.4.0
2022-07-30T20:54:03.623Z [err] npm
2022-07-30T20:54:03.624Z [err] WARN config production Use `--omit=dev` instead.
2022-07-30T20:54:09.125Z [out]
2022-07-30T20:54:09.125Z [out] added 50 packages in 6s
2022-07-30T20:54:09.137Z rc=0
2022-07-30T22:19:08.728Z Install : node-red-contrib-ewelink 2.0.0
2022-07-30T22:19:08.736Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-ewelink@2.0.0
2022-07-30T22:19:08.977Z [err] npm
2022-07-30T22:19:08.977Z [err] WARN config production Use `--omit=dev` instead.
2022-07-30T22:19:18.112Z [err] npm
2022-07-30T22:19:18.112Z [err] ERR! code ENOENT
2022-07-30T22:19:18.112Z [err] npm ERR! syscall spawn git
2022-07-30T22:19:18.112Z [err] npm ERR! path
2022-07-30T22:19:18.112Z [err] git
2022-07-30T22:19:18.113Z [err] npm ERR!
2022-07-30T22:19:18.113Z [err] errno -2
2022-07-30T22:19:18.115Z [err] npm ERR!
2022-07-30T22:19:18.115Z [err] enoent An unknown git error occurred
2022-07-30T22:19:18.115Z [err] npm ERR! enoent This is related to npm not being able to find a file.
2022-07-30T22:19:18.117Z [err]
2022-07-30T22:19:18.117Z [err] npm
2022-07-30T22:19:18.117Z [err] ERR! A complete log of this run can be found in:
2022-07-30T22:19:18.117Z [err] ERR! /root/snap/node-red/815/.npm/_logs/2022-07-30T22_19_08_954Z-debug-0.log
2022-07-30T22:19:18.128Z rc=254
I want to know if the snap installation of Node-Red is the cause of failing to install the palette or if is it something else.
Can someone with the snap installation of Node-Red and someone without snap installation of Node-Red can try to install the ewelink palette and tell me if they are getting any errors on installation?.
Colin
31 July 2022 06:16
2
Have you tried installing git?
If in doubt don’t use the snap. It is very restricted and doesn’t have access to others apps on the host.
git installed on my computer.
Not sure why but node-red-contrib-ewelink-copy (node) - Node-RED get installed, which is a copy of what I have asked for to test.
So I guess the original one didn't work because of other reasons and not because of the snap.
