The latest NodeRed does not work on HomeAssistant
Hi have updated Node Red 13.3.0 to the latest version Node-RED 13.5.3 running on Home Assistant 2022.11.4,
Post upgrade of NodeRed to 13.5.3, I'm unable to access my configurations in Node-Red. It reports an error that Node-Red is not running. I restart the Node-Red service however it reports the same issue when trying the access the Node-Red configuration, the Node-Red service crashes.
All my automations are done by Node Red, so this is causing major problems to my home automation.
I restore a backup of Node-Red version 13.3.0 and all works correctly, however Node-Red autoupdates to the latest version after a few hours which initiates the same problem and all my automation stops working again.
I would appreciate any assistance regarding this matter.
Best regards
Harry
Node red is currently on version 3.0.2 so I guess you are talking about the node-red plugin in HA. You will have to ask on an HA forum about that as they provide the plugin.
Hi Colin,
I have just list another post with more detail.
Thank you for your response much appreciated..
I will also raise it with HA, hopefully I can get it resolved as none of my automations work as all automations are do within Node-Red.
Once again thanks for your response.
Best regards
Harry
