Treeview filter and selected node
Hi folks,
i try to make a Treeview for filter and selecting some hierarchical data.
i stuck on the click part: When i select a node, i want to emit the id of the clicked node.
i also try to add a filter, but also stuck there.
https://vuetifyjs.com/en/api/v-treeview/
Can someone give me a hint?
Current state i a template node with this content:
<template>
    <v-treeview :items="items"
    item-value="id"
    activatable
    @update:selected="send({payload: value})"
    @click:select="send({payload: value})"
    </v-treeview>
</template>
<script>
    export default {
    data: () => ({
      items: [
          title: 'Applications :',
          children: [
            { id: 2, title: 'Calendar : app' },
            { id: 3, title: 'Chrome : app' },
            { id: 4, title: 'Webstorm : app' },
          title: 'Documents :',
          children: [
              title: 'vuetify :',
              children: [
                  title: 'src :',
                  children: [
                    { id: 8, title: 'index : ts' },
                    { id: 9, title: 'bootstrap : ts' },
    watch: {
        // watch for any changes of "count"
    computed: {
        // automatically compute this variable
        // whenever VueJS deems appropriate
    methods: {
        // expose a method to our <template> and Vue Application
    mounted() {
        // code here when the component is first loaded
    unmounted() {
        // code here when the component is removed from the Dashboard
        // i.e. when the user navigates away from the page
</script>
