I'm using 'hass-node-red' to trigger Node-RED from Home Assistant. That works well.
But I have also a cover templete in which I also want to call Node-RED. That is not working with the arguments. Do somebody know if this is possible?
cover:
- platform: template
covers:
safe_test_cover:
device_class: shutter
friendly_name: "SAFE test cover"
position_template: "{{ state_attr('cover.05_hal_1e_etage', 'current_position' ) | int }}"
open_cover:
service: cover.open_cover
data:
entity_id: cover.05_hal_1e_etage
close_cover:
service: nodered.trigger
data:
entity_id: switch.safe_close_cover_slowly
stop_cover:
service: cover.stop_cover
data:
set_cover_position:
data_template:
entity_id: switch.safe_set_cover_position_slowly
position: "{{position | int}}"
currentposition: "{{ state_attr('cover.05_hal_1e_etage', 'current_position' ) | int }}"
So the close_cover is working (there are no arguments required).
The set_cover_position doesn't works. Extra keys not allowed @data['position']
