yoyo89
30 November 2018 23:48
1
Does anybody know why i get this error
it was working fine then it happened ,i deleted my node-red instance from IBM bluemix installed again ,it worked for sometime then i had the same error :"Error on connection for TTN application yo1989: Error: 14 UNAVAILABLE: Connect Failed"
Colin
1 December 2018 07:12
2
Can you post the node red log from a node red restart please. Up to the error.
yoyo89
1 December 2018 07:25
3
I don’t understand? What do you mean ?
Colin
1 December 2018 07:35
4
Just realised you are running on bluemix, sorry I don't know how to get the log on there.
yoyo89
3 December 2018 20:37
5
Hello Colin i downloaded node-red and this is what i get same problem
That shows the node cannot connect to TTN (error 14)
you should probably either read their docs or ask them what that error number really means
yoyo89
3 December 2018 21:03
7
i read that is a common error in node-red but i didnt find the solution
where did you read at it was a common error?
Perhaps ask there how to fix it.
