UI design in node automatically according to number of CAN bus
I am designing a flow in which gateway side i am sending data to door controller via can bus and to node red ui through mqtt .I have to design UI for door on/off button and status of door in text ,but automatically it means x no of can bus if i am using then x no. of door ui would automatically designed in node red.Please help .
thank you
Assuming you are using the Node-RED Dashboard, you will need to read up on using Angular v1's loop feature. You can then use this in a ui_template node.
firstly thank you sir for giving answer,but can you tell how to use Angular v1 loops ,i really need help in this.
ng-repeat is what you need to investigate. I'm afraid I no longer regularly use Dashboard and don't currently have time to expand. You will certainly find examples however, both in this forum, on the Flows site and on the Internet.
Sir i searched but not getting any idea.please can you help
https://www.startpage.com/do/dsearch?query=ng-repeat+node-red&cat=web&pl=opensearch&language=english_uk
Thank you Sir.I will read this and ask my doubts if any .
