UI inputs to control timer
I have been working on controlling a pump to teach myself how to use node-red. So far I can turn the pump on/off, change direction and control the speed all through the dashboard. I would really like to be able to turn it on and off through the dashboard by selecting a time. For instance, turn on at 16:00 and turn it off at 16:05. Has anyone done anything like this?
Am I maybe jumping too far ahead with my learning? I guess what I need is a timing module that can be controlled from the dashboard.
Any help will be gratefully received.
R
Hej,
this one could do the trick:
Thanks for you help, I will have a look today
Yes, this was exactly what I need. It works perfectly. Thank you for helping me out
