Ui-text vertical spacing
When stacking ui-text widgets there is a lot of vertical padding between each widget. Is there a way to remove this so that the actual text from each widget is vertically snug against each other? Some magic css maybe?
I would prefer not to introduce a template node.
Cheers
Bob
Hi @Bobo, thanks for the question. On your theme there is a "Widget Gap" option, which you can set to zero.
Currently a single row in Dashboard is 48px, and isnt configurable, but want to emphasise the currently.
It's something that is coming up a lot, and we'll hopefully get addressed in the next week or two, which would be the introduction of a "compact" view, where the padding is reduced considerably
There is magic of the CSS of course.
Anyway, it is not correct way to solve the problem. Fighting with layout instead of being creative... I'd use ui_template to create rows which you can then modify as you need.
Thanks to you both. Appreciate it. :+1:
Any luck with this one?
Cheers
Not yet, sorry, its still one of the top priorities and I'll post to the forums, and publish a blog about it to https://flowfuse.com (and their socials) when it's available
