I am hosting my node-red solution to Google cloud platform. Once I installed the worldmap pallet, I found the ui_worldmap is not working. Any help on that please?
Thank you
Thank you
Can you define "not working"
Is there a error or empty webpage or....
I meant this. It is not showing active.
Do you have node-red-dashboard installed ? That is a pre-req for that up node.
(The world map will still work without it)
Yes, I installed it.
Then that is most odd - can you share the startup console log when you restart Node-RED ?
