Hi all, managed to get a new feature release out pretty quickly this time. Not too many new features but one or two that may be of interest.
The zero-code Simple Form in
uib-elementhas been significantly updated with better formatting and better information coming back to Node-RED on a button press. You also no longer have to define any buttons in the form, they will be added for you if you don't provide any. -
The zero-code example has been improved to show off the new
uib-elementForms update. -
A new example, "remote-commands" shows off how to remotely configure the front-end library and get information back from it.
There are a bunch of new functions in the client library. They can all be used either in custom front-end code or "remotely" from Node-RED (check them out using the new example):
includelets you load external URL's (from files or API's) into a given position in the web page. These can be anything - HTML snippets, images, video, PDF's, ... -
htmlSendlets you send the whole page HTML back to Node-RED -
uiWatchlets you watch for changes to 1 or more on-page elements and will send the details of the changes back to Node-RED. This is great if you have multiple flows updating the page or you are using a mix of front-end custom code and Node-RED flows to update things.
The
uib-sendernode now adjusts if you rename the uibuilder node it is linked to.
And of course, a few bug-fixes have also been included. The Svelte template now works properly again (after a breaking change in one of the libraries). A small but annoying bug in the client library that caused an error in some circumstances when it tried to load a style sheet.
Hope you find these updates useful. As always, please let me know if you find an issue or have an idea you'd like to see included in a future release. Also, if you want to contribute either code or documentation updates, you would be more than welcome.
I'll be trying to get a few more videos out soon as well.
Changelog
General
localesfolder withen-USsubfolder. Ready for l8n.
Client library changes
Bug Fix: Issue #201 - Incorrect logic in stylesheet load causing an error. Fixed.
New functions - can be run from Node-RED as well as front-end code:
htmlSend()- sends the current web page back to Node-RED.uiWatch(cssSelector, startStop=true/false/'toggle', send=true, showLog=true)- watches for any changes to the selected page elements and usesuiGetto send useful data back to Node-RED automatically. It should also trigger a custom event to allow front-end processing too. IfstartStopis undefined, null or 'toggle', the watch will be toggled.include(url, uiOptions)- include external files. Includes HTML, Images, Video, PDF's and more.
New internal functions:
nodeGet(domNode)- gets standard data from a DOM node (used internally by uiGet and uiWatch for consistency).
Updated functions:
uiGet- now usesnodeGetfor consistency withuiWatch.$- now returns first child if selector returns a<template>tag. Warn/Error logging added.
uib-element node changes
- Bug Fix: Updating the page title (with no html id set) was setting the mode to "add" which upset chained outputs. Now corrected.
- "Form" type - improvements:
- Where
requiredproperty is true in the input, addclass="required"to the div that wraps the label and input. Adddiv.required label::afterstyling touib-brand.css. This will add an "*" after the label text for required inputs. See theuib-brand.cssupdates for more formatting improvements. - Allow
titleproperty to be set in input data. Also add "Required. " to start of title. If no title property specified, make itType: ${type}. - If no button included in the input data, add default send and reset buttons with an id of
${elementId}-btn-send&${elementId}-btn-reset. The Send button uses the standardeventSendfunction. The Reset button returns all form inputs back to their defaults. - Formatting improvements: Inputs are outlined with
--successif they pass validation and with--failureif they do not. Any buttons on the form are given--warningcolour if the form does not validate. The buttons still work however. - Form data improvements: Using the
eventSendwithin a form element includes data saying whether the form validates. The details for each input also say whether they validate and if they don't, why. - The documentation for "Zero-code element types" > "Forms" completed.
- Where
uib-sender node changes
- Add the uibuilder node link node id to config data & expand editor checks for url changes. Will mark the node instance as needing re-deployment if the linked uibuilder node changed its URL. This is done by also tracking and recording the node id of the linked uibuilder node.
uib-brand.css updates
- Added intense (more saturated) versions of info, success, warning/warn, failure/error/danger.
- Added
centeras a synonym ofcentre. - Added
surface5which has higher lightness than 4. - Forms formatting extended.
- Form labels are shown in Title Text (first letter of each word capitalised). If attached to a required input, an "*" is shown after the label.
- Input valid/invalid formatting added. Borders set to
--success,--failurecollours accordingly - Buttons on an invalid form set to
--warningcolour.
Standard Templates
- Bug Fix: Issue #204 - change to
rollup.config.jscaused issues with bundled css. Fixed.
Examples
- zero-code: Improved Forms example shows off more options. Example for light/dark mode added. On-(re)load flow attached to the control output of the uibuilder node; automatically changes the page title (an alternative to using a cache node).
- New Example: Remote-Commands - Demonstrates all of the uibuilder client library functions that can be called from Node-RED.
