UIbuilder showing 0.0.0.0:1880
Welcome to Node-RED
10 Jan 18:46:47 - [info] Node-RED version: v3.0.0
10 Jan 18:46:47 - [info] Node.js  version: v16.19.0
10 Jan 18:46:47 - [info] Linux 5.15.0-57-generic x64 LE
10 Jan 18:46:47 - [info] Loading palette nodes
10 Jan 18:46:47 - [debug] array-permutations logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] array-permutations Copyright 2020-2022 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] combinations logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] combinations Copyright 2022 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] combinationLoop logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] combinationLoop Copyright 2022 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] permutations logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] permutations Copyright 2022 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] permutationLoop logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] permutationLoop Copyright 2022 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] permutationRandom logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] permutationRandom Copyright 2022 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] permutationsCallable logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] permutationsCallable Copyright 2022 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] permutationsCircular logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] permutationsCircular Copyright 2022 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] permutationHeap logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] permutationHeap Copyright 2022 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] permutationsUnique logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] permutationsUnique Copyright 2022 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] logger Node logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] logger Node Copyright 2020 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] logger Node test active
10 Jan 18:46:47 - [debug] append logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] append Copyright 2020 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] Data Analysis logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] Data Analysis Copyright 2020 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] Host Available logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] Host Available Copyright 2020 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] Levenshtein Distance logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] Levenshtein Distance Copyright 2020 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] LevenshteinDistance logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] LevenshteinDistance Copyright 2020 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] Load Injector logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] Load Injector Copyright 2020 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] matrix logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] matrix Copyright 2022 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] Matrix logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] Matrix Copyright 2022 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] Monitor Flow logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] Monitor Flow Copyright 2020 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] os logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] os Copyright 2020 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] Spawn Process logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] Spawn Process Copyright 2020 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] test logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] test Copyright 2020 Jaroslav Peter Prib
10 Jan 18:46:47 - [debug] transform logging turning on logging next 111 log points
10 Jan 18:46:47 - [info] transform Copyright 2020 Jaroslav Peter Prib
10 Jan 18:46:48 - [info] Dashboard version 3.3.1 started at /ui
10 Jan 18:46:48 - [info] Settings file  : /home/epicenter/.node-red/settings.js
10 Jan 18:46:48 - [info] HTTP Static    : /home/epicenter/node-red/static > /
10 Jan 18:46:48 - [info] Context store  : 'default' [module=memory]
10 Jan 18:46:48 - [info] User directory : /home/epicenter/.node-red
10 Jan 18:46:48 - [warn] Projects disabled : editorTheme.projects.enabled=false
10 Jan 18:46:48 - [info] Flows file     : /home/epicenter/.node-red/status
10 Jan 18:46:48 - [info] Creating new flow file
10 Jan 18:46:48 - [warn] Using unencrypted credentials
10 Jan 18:46:48 - [info] +-----------------------------------------------------
10 Jan 18:46:48 - [info] | uibuilder v6.0.0 initialised
10 Jan 18:46:48 - [info] | root folder: /home/epicenter/.node-red/uibuilder
10 Jan 18:46:48 - [info] | Using Node-RED's webserver at:
10 Jan 18:46:48 - [info] |   http://0.0.0.0:1880/
10 Jan 18:46:48 - [info] | Installed packages:
10 Jan 18:46:48 - [info] |   bootstrap, bootstrap-vue, jquery, moonjs
10 Jan 18:46:48 - [info] |   vue
10 Jan 18:46:48 - [error] Uncaught Exception:
10 Jan 18:46:48 - [error] Error: listen EADDRINUSE: address already in use 0.0.0.0:1880
    at Server.setupListenHandle [as _listen2] (node:net:1463:16)
    at listenInCluster (node:net:1511:12)
    at doListen (node:net:1660:7)
    at processTicksAndRejections (node:internal/process/task_queues:84:21)
Not sure how to fix this issue.
Usually that means that you already have node red running. Make sure you stop node red before trying to start it again.
uibuilder showing 0.0.0.0 as its IP address is NOT a uibuilder issue and isn't the reason Node-RED won't start.
uibuilder is showing as available on 0.0.0.0 because that is what Node-RED has been set to work on. It means that Node-RED's web servers are set to be available on all network interfaces on the server. uibuilder is, therefore, following along. This is the default setting for Node-RED on Linux devices.
As Colin has said, the failure is due to you already having port 1880 in use - almost certainly because Node-RED is already running when you try to start it again.
