Unable to install opc ua to palette
I want to add the node-red-contrib-opcua to the palette. I actually installed it with npm, but I can't find it in node red.
Then I tried to install it directly through the mange palette, that didn't work either.
To install with NPM, you need to
  • install to the userDir folder
    • usually .node-red but check the logs to be certain (look for the node-red entry that states userDir)
  • restart node-red
  • refresh browser
Additionally, you have installed as root - why?
what user runs node-red?
Lastly, I see this is an iot2000 box - I suspect the node-js and node-red version will probably be to old.
Thank you for your reply. I changed to the latest image and it worked.
