Unable to install sqlite node
I keep getting this error when trying to install the sqlite node. I'm running node-red with Home Assistant.
2021-08-06T22:31:43.329Z Install : node-red-node-sqlite 0.6.0
2021-08-06T22:31:43.691Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production node-red-node-sqlite@0.6.0
2021-08-06T22:31:52.736Z [err] npm
2021-08-06T22:31:52.737Z [err]  ERR! code ENOTEMPTY
2021-08-06T22:31:52.737Z [err] npm ERR! syscall rename
2021-08-06T22:31:52.737Z [err] npm ERR! path /config/node-red/node_modules/zigbee-herdsman/node_modules/ansi-regex
2021-08-06T22:31:52.738Z [err] ERR! dest /config/node-red/node_modules/zigbee-herdsman/node_modules/.ansi-regex-tqk0FjqF
2021-08-06T22:31:52.738Z [err] npm
2021-08-06T22:31:52.738Z [err]  ERR! errno -39
2021-08-06T22:31:52.744Z [err] npm ERR!
2021-08-06T22:31:52.745Z [err]  ENOTEMPTY: directory not empty, rename '/config/node-red/node_modules/zigbee-herdsman/node_modules/ansi-regex' -> '/config/node-red/node_modules/zigbee-herdsman/node_modules/.ansi-regex-tqk0FjqF'
2021-08-06T22:31:52.769Z [err]
2021-08-06T22:31:52.770Z [err] npm ERR! A complete log of this run can be found in:
2021-08-06T22:31:52.770Z [err] npm ERR!     /root/.npm/_logs/2021-08-06T22_31_52_749Z-debug.log
2021-08-06T22:31:52.807Z rc=217
Do you have sqlite installed on the device you are running NR on?
Wa\hat device is running NR?
