I imported an example flow to look at how it worked.
It had server settings in it and when i deleted the flow i also deleted the server.
However something is still trying to reference it, but i cannot see it on any of my flows:
11/08/2019, 16:23:06Home Assistantmsg : string[158]
"Home assistant connection failed with error: Connection to home assistant could not be established with config: http://192.168.86.168:8123 <password redacted>"
how do I remove this, please?
You will find it at the hamburger menu -> configuration nodes
thats the problem. it is not listed there.
the only one listed it the one with the correct settings
You clicked "unused" and that list is empty ?
In the editor cmd+f or ctrl+f and search for home assistant, also doesn't show up ?
restarted node-red ? weird stuff!
i restarted the docker container
In the debug window, do you see the source node ?
You can click the number, or when you hover your mouse over the message you should see a node being selected.
No mine just gives
