Unable to show labels on bar chart
With this function I read data from a txt file. Because there may be more lines of data for the same month, the function will use the last one for each month.
// Function to process load shedding data
const processLastEntryPerMonth = (lines) => {
    let monthlyData = {};
    lines.forEach(line => {
        let parts = line.split(': ');
        if (parts.length === 2) {
            let date = new Date(parts[0]);
            let month = date.toLocaleString('en-US', { month: 'long' });
            let timeParts = parts[1].split(':');
            let hours = parseInt(timeParts[0]) + parseInt(timeParts[1]) / 60;
            monthlyData[month] = hours; // Store the last value for each month
    return monthlyData;
// Assuming msg.payload is the raw data from your file
const lines = msg.payload.split('\n').filter(line => line.trim() !== '');
let monthlyData = processLastEntryPerMonth(lines);
// Format data for the chart
let m = {
    series: [""],
    data: [],
    labels: []
for (let month in monthlyData) {
    m.labels.push(month); // Month names as labels
    m.data.push(Math.round(monthlyData[month])); // Load shedding hours for each month
return { payload: [m], topic: msg.topic };
My problem is that I am unable to show the labels (Month name) for each bar.
This is my actual result
What am I doing wrong? Why the labels (January, February) are not showing under the relevant bars?
Thanks for helping
Try
 m.data[0].push(Math.round(monthlyData[month]));
As data should be a array of array/s.
And
let m = {
    series: [""],
    data: [[]],
    labels: []
Thank you. That did it!
Hi, what version of node-red Dashboard are you using? I and using Dashboard v2 and also having problems finding the right way to build my data.
If you have an issue with the dashborad 2 ui-chart please start a topic with your question, include incoming data and describe in full your expected output, and issues you are gaving.
More Info of chart in dashboard 2 here Chart ui-chart | Node-RED Dashboard 2.0
