Unable to visible the tcp node settings(Solved)
Hello geeks
just getting started using of Node red few days ago on my windows pc, Successfully installed Node red and npm packages
every thing is working great for me, but today when i create the new flow with the TCP node then I'm unable to visible the properties of the TCP node like port/ip and listening or sending etc!!! And when i choose another node like mqtt, http or web-socket then i can do so :grinning:. That's the really wired situation for me
here I'm attaching the few images of the tcp node
any suggestions?
all suggestions and comments welcome
I would try closing that browser tab, close then restart Node-RED and then re-open the tab and see if the fault is still present
thanks for the reply
yes, I’ve try it closed browser page, restart node red and reset the node-red local host page but still the problem is there!
I’ve also try with the different browser (i.e firefox) but still the problem is not salved
How have you installed Node-RED?
What version of Windows are you running it on?
What version of Node-RED and Nodejs have you installed?
Have you checked the information here:
https://nodered.org/docs/platforms/windows
especially the yellow boxes?
You seem to have got the bluemix version of the nodes installed on a local deployment… you need to remove them (plus any other bluemix nodes you installed at the same time.)
please have a look
I'm using Windows 7 version
Thanks for the reply
I’ll try and update here
yeah, got the issue
that is the problem of Bluemix nodes installed on local machine
thanks
dceejay
