Unknown Function Calls from Terminal
The moment I open the Nodered Terminal from the Nodered Icon on my raspberri pi, the terminal stars issuing uninitiated function calls (convert to Hex) automatically every 10 seconds, with no action from my end.
After I log in and open nodered, error messages as a consequence of these commands starts scrolling in the debug window every 10 secs. This is with a blank flow page with no nodes on it.
How can I get over this issue ?
Terminal text is copied and reproduced below;
Start Node-RED
Once Node-RED has started, point a browser at http://192.168.1.181:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use node-red-stop to stop Node-RED
Use node-red-start to start Node-RED again
Use node-red-log to view the recent log output
Use sudo systemctl enable nodered.service to autostart Node-RED at every boot
Use sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
10 Dec 10:47:09 - [error] [function:Convert to Hex] TypeError: Cannot read properties of undefined (reading 'toString')
10 Dec 10:47:19 - [error] [function:Convert to Hex] TypeError: Cannot read properties of undefined (reading 'toString')
10 Dec 10:47:29 - [error] [function:Convert to Hex] TypeError: Cannot read properties of undefined (reading 'toString')
10 Dec 10:47:39 - [error] [function:Convert to Hex] TypeError: Cannot read properties of undefined (reading 'toString')
10 Dec 10:47:59 - [error] [function:Convert to Hex] TypeError: Cannot read properties of undefined (reading 'toString')
10 Dec 10:48:09 - [error] [function:Convert to Hex] TypeError: Cannot read properties of undefined (reading 'toString')
10 Dec 10:48:19 - [error] [function:Convert to Hex] TypeError: Cannot read properties of undefined (reading 'toString')
10 Dec 10:48:29 - [error] [function:Convert to Hex] TypeError: Cannot read properties of undefined (reading 'toString')
My node red version is v16.18.1
How did you install node-red ? (the version you showed is the nodejs version, not node-red).
See documentation, how to install on a raspberry pi.
Using this script;
bash <(curl -sL https://raw.githubusercontent.com/node-red/linux-installers/master/deb/update-nodejs-and-nodered) --node16
You probably have a hidden flow.
Try clicking the top of the debug message. It should take you directly to the function.
Alternatively search for "convert" (ctrl+f)
Alternatively use the command palette to show all flows (ctrl+shift+p, type flow)
Got it. Thanks steve-mcl.
