Unknown node types: googleCredentials
I've gotten a bit sidewards at the moment as I deleted node-red-contrib-google-oauth-calendar and suddenly I got complaints about googleCredentials.
I've added node-red-contrib-google-oauth-calendar back in but I continue to get this:
The workspace contains some The workspace contains some unknown node types:
googleCredentials
Are you sure you want to deploy?
I see the that node-red-contrib-google-oauth-calendar has googleCredentials 'in use' but I can't figure out how to get it unused so I can remove node-red-contrib-google-oauth-calendar.
Press CTRL-F, search for googleCredentials, delete it.
It is likely in the config nodes on the side-bar
Thanks, that worked great!
