Unsuccessful installation of Node Red on Ubuntu 16.04 LTS
I'm trying to install Node Red in a desktop with Ubuntu 16.04 LTS operating system.
Already successfully installed Node.js (v4.2.6) and npm (v3.5.2).
But when I try to install Node Red using the command sudo npm install -g --unsafe-perm node-red, the things start to not working.
Can someone help me?
The error is as follows:
jhluna@nodered:~$ sudo npm install -g --unsafe-perm node-red
loadDep:bcrypt → resolveW
loadDep:punycode → networ
loadDep:readable-stream →
npm WARN deprecated nodemailer@1.11.0: All versions below 4.0.1 of Nodemailer are deprecated. See Status :: Nodemailer
npm WARN deprecated mailparser@0.6.2: Mailparser versions older than v2.3.0 are deprecated
npm WARN deprecated mimelib@0.3.1: This project is unmaintained
npm WARN deprecated mailcomposer@2.1.0: This project is unmaintained
npm WARN deprecated buildmail@2.0.0: This project is unmaintained
loadDep:uuid → resolveWit
/usr/local/bin/node-red -> /usr/local/lib/node_modules/node-red/red.js
/usr/local/bin/node-red-pi -> /usr/local/lib/node_modules/node-red/bin/node-red-pi
bcrypt@2.0.1 install /usr/local/lib/node_modules/node-red/node_modules/bcrypt
node-pre-gyp install --fallback-to-build
node-pre-gyp ERR! UNCAUGHT EXCEPTION
node-pre-gyp ERR! stack TypeError: this is not a typed array.
node-pre-gyp ERR! stack at Function.from (native)
node-pre-gyp ERR! stack at Object. (/usr/local/lib/node_modules/node-red/node_modules/bcrypt/node_modules/tar/lib/parse.js:33:27)
node-pre-gyp ERR! stack at Module._compile (module.js:410:26)
node-pre-gyp ERR! stack at Object.Module._extensions..js (module.js:417:10)
node-pre-gyp ERR! stack at Module.load (module.js:344:32)
node-pre-gyp ERR! stack at Function.Module._load (module.js:301:12)
node-pre-gyp ERR! stack at Module.require (module.js:354:17)
node-pre-gyp ERR! stack at require (internal/module.js:12:17)
node-pre-gyp ERR! stack at Object. (/usr/local/lib/node_modules/node-red/node_modules/bcrypt/node_modules/tar/lib/list.js:10:16)
node-pre-gyp ERR! System Linux 4.15.0-43-generic
node-pre-gyp ERR! command "/usr/bin/nodejs" "/usr/local/lib/node_modules/node-red/node_modules/bcrypt/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd /usr/local/lib/node_modules/node-red/node_modules/bcrypt
node-pre-gyp ERR! node -v v4.2.6
node-pre-gyp ERR! node-pre-gyp -v v0.9.1
node-pre-gyp ERR! This is a bug in node-pre-gyp.
node-pre-gyp ERR! Try to update node-pre-gyp and file an issue if it does not help:
node-pre-gyp ERR! https://github.com/mapbox/node-pre-gyp/issues
npm WARN install:bcrypt@2.0.1 bcrypt@2.0.1 install: node-pre-gyp install --fallback-to-build
npm WARN install:bcrypt@2.0.1 Exit status 7
/usr/local/lib
└── node-red@0.19.5
You need a more recent version of Node. We recommend Node 8.x.
In fact the easiest way is to use the Pi install script in the installation docs. It works fine on Ubuntu.
Thank you both.
I have performed the following procedures to be able to update Node.js to version 8.x:
sudo apt install curl
curl -sL https://deb.nodesource.com/setup_8.x | sudo bash -
sudo apt-get install -y nodejs
After that, the Node.js and npm was updated, respectively, to v8.15.0 and 6.4.1 and I could install the Node Red using Pi install script as @Colin sad. The script was:
bash <(curl -sL https://raw.githubusercontent.com/node-red/raspbian-deb-package/master/resources/update-nodejs-and-nodered)
The sources were:
https://nodered.org/docs/hardware/raspberrypi
Too late now, but just for reference, the Pi script would have upgraded node.js for you (using the same technique you did).
