In the latest home assistant update, nodered has updated the modbus modules and there seems to be a problem and they have been disabled and I cannot reinstall or enable them.
you can help us.
thank you
UnborN
15 February 2022 13:41
2
seems to be a home-assistant node-red modbus issue
there is a discussion on the hassio Github page with some suggestions that you may find useful
since i dont use HA im sharing the link
opened 01:51PM - 14 Feb 22 UTC
closed 11:52AM - 15 Feb 22 UTC
Modbus stopped working after the latest update of Node Red.
got this from the l… ogg :
14 Feb 14:51:04 - [warn] [node-red-contrib-modbus/Modbus-Flex-Getter] Error: Cannot find module 'source-map-support'
Require stack:
- /opt/node_modules/node-red-contrib-modbus/modbus/modbus-flex-getter.js
- /opt/node_modules/@node-red/registry/lib/loader.js
- /opt/node_modules/@node-red/registry/lib/index.js
- /opt/node_modules/@node-red/runtime/lib/nodes/index.js
- /opt/node_modules/@node-red/runtime/lib/index.js
- /opt/node_modules/node-red/lib/red.js
- /opt/node_modules/node-red/red.js
14 Feb 14:51:04 - [warn] [node-red-contrib-modbus/Modbus-Write] Error: Cannot find module 'source-map-support'
Require stack:
- /opt/node_modules/node-red-contrib-modbus/modbus/modbus-write.js
14 Feb 14:51:04 - [warn] [node-red-contrib-modbus/Modbus-Flex-Write] Error: Cannot find module 'source-map-support'
Require stack:
- /opt/node_modules/node-red-contrib-modbus/modbus/modbus-flex-write.js
14 Feb 14:51:04 - [warn] [node-red-contrib-modbus/Modbus-Server] Error: Cannot find module 'source-map-support'
Require stack:
- /opt/node_modules/node-red-contrib-modbus/modbus/modbus-server.js
14 Feb 14:51:04 - [warn] [node-red-contrib-modbus/Modbus-Flex-Server] Error: Cannot find module 'source-map-support'
Require stack:
- /opt/node_modules/node-red-contrib-modbus/modbus/modbus-flex-server.js
14 Feb 14:51:04 - [warn] [node-red-contrib-modbus/Modbus-Queue-Info] Error: Cannot find module 'source-map-support'
Require stack:
- /opt/node_modules/node-red-contrib-modbus/modbus/modbus-queue-info.js
14 Feb 14:51:04 - [warn] [node-red-contrib-modbus/Modbus-Flex-Connector] Error: Cannot find module 'source-map-support'
Require stack:
- /opt/node_modules/node-red-contrib-modbus/modbus/modbus-flex-connector.js
14 Feb 14:51:04 - [warn] [node-red-contrib-modbus/Modbus-IO-Config] Error: Cannot find module 'source-map-support'
Require stack:
- /opt/node_modules/node-red-contrib-modbus/modbus/modbus-io-config.js
14 Feb 14:51:04 - [warn] [node-red-contrib-modbus/Modbus-Response-Filter] Error: Cannot find module 'source-map-support'
Require stack:
- /opt/node_modules/node-red-contrib-modbus/modbus/modbus-response-filter.js
14 Feb 14:51:04 - [warn] [node-red-contrib-modbus/Modbus-Flex-Sequencer] Error: Cannot find module 'source-map-support'
Require stack:
- /opt/node_modules/node-red-contrib-modbus/modbus/modbus-flex-sequencer.js
