Update of NodeRed-container in Portainer 1.17.1 - Node RBE - Type_already_registered
after the update of NodeRed to V2.x.x I get the type_already_registeres message with the RBE-node.
I have read in other topics that the rbe-node has been replaced with the filter-node.
All my nodes are still shown as "rbe". A double-click on it states them then as "filter".
I have tried "npm remove node-red-node-rbe" or "npm uninstall node-red-node-rbe" in the command window of Portainer and after that restarted the container.
bash-5.0$ npm remove node-red-node-rbe
audited 317 packages in 55.121s
29 packages are looking for funding
  run `npm fund` for details
found 0 vulnerabilities
Unfortunately there is no difference, the rbe-node is still shown in the palette manager and also on the flows.
How do I remove the rbe-node and this warning?
Looking forward for help, thanks
Wolfgang
Welcome to the forum @Eraser
When you ran the npm remove command, were you in the folder where the package.json and node_modules folders are located? When you run it you should see a message telling you that it removed one or more packages.
Hello Colin,
thanks for your answer.
Yes both are in this folder:
bash-5.0$ ls -la
total 140
drwxrwxr-x    1 node-red root          4096 Jan  4 08:25 .
drwxr-xr-x    1 root     root          4096 Dec  5 09:51 ..
-rw-------    1 node-red node-red        63 Jan  4 08:25 .bash_history
drwx------    3 node-red node-red      4096 Jan  4 07:48 .config
drwxr-xr-x    5 node-red node-red      4096 Jan  4 09:56 .npm
drwxr-xr-x    1 node-red root          4096 Jan  4 08:19 node_modules
-rw-r--r--    1 node-red node-red    111535 Jan  4 08:19 package-lock.json
-rw-r--r--    1 node-red node-red      1063 Jan  4 08:19 package.json
bash-5.0$
Your node_modules folder is owned by root. I guess you installed using sudo at some point. Change the ownership of that folder and all contained files/folders. Then run
npm install node-red-node-rbe
Then restart node-red. If still no joy then what do these commands show
npm list node-red-node-rbe
sudo npm list -g node-red-node-rbe
I didn't install it with sudo rights.
This is just the latest NodeRed-image for docker (nodered/node-red:latest)
There is one additional volume which maps to /data to ensure that I can easily upgrade NodeRed without having every data wiped.
Here is what I get with your command:
bash-5.0$ npm list node-red-node-rbe
node-red-docker@2.1.4 /usr/src/node-red
`-- (empty)
bash-5.0$
Thanks for your ongoing help
Wolfgang
What is in the /data folder?
This is in the data-volume, which is mapped to /data:
bash-4.3# ls -la
total 52
drwxr-xr-x    1 root     root          4096 Jan  4 13:34 .
drwxr-xr-x    1 root     root          4096 Jan  4 13:34 ..
drwxr-xr-x    1 root     root          4096 Jan 30  2019 cache
dr-xr-xr-x    2 root     root          4096 Jan 30  2019 empty
drwxr-xr-x    5 root     root          4096 Jan 30  2019 lib
drwxr-xr-x    2 root     root          4096 Jan 30  2019 local
drwxr-xr-x    3 root     root          4096 Jan 30  2019 lock
drwxr-xr-x    2 root     root          4096 Jan 30  2019 log
drwxrwxr-x    6 1000     root          4096 Jan  4 10:48 nodered_data
drwxr-xr-x    2 root     root          4096 Jan 30  2019 opt
drwxr-xr-x    2 root     root          4096 Jan 30  2019 run
drwxr-xr-x    3 root     root          4096 Jan 30  2019 spool
drwxrwxrwt    2 root     root          4096 Jan 30  2019 tmp
bash-4.3# cd nodered_data
bash-4.3# ls -la
total 432
drwxrwxr-x    6 1000     root          4096 Jan  4 10:48 .
-rw-r--r--    1 1000     1000         16025 Oct 31  2020 .config.json
-rw-r--r--    1 1000     1000         16121 Oct 31  2020 .config.json.backup
-rw-r--r--    1 1000     1000         29589 Jan  4 07:03 .config.nodes.json
-rw-r--r--    1 1000     1000         29662 Jan  4 07:03 .config.nodes.json.backup
-rw-r--r--    1 1000     1000             2 Nov  1  2020 .config.projects.json
-rw-r--r--    1 1000     1000            95 Nov  1  2020 .config.runtime.json
-rw-r--r--    1 1000     1000           626 Jan  4 08:19 .config.users.json
-rw-r--r--    1 1000     1000           626 Jan  4 08:19 .config.users.json.backup
-rw-r--r--    1 1000     1000        116077 Jan  4 10:48 .flows.json.backup
-rw-r--r--    1 1000     1000           152 Jan  4 06:29 .flows_cred.json.backup
drwxr-xr-x    4 1000     1000          4096 Jan  4 06:58 .npm
-rw-r--r--    1 1000     1000        116077 Jan  4 10:48 flows.json
-rw-r--r--    1 1000     1000           124 Jan  4 06:29 flows_cred.json
drwxr-xr-x    3 1000     1000          4096 Sep  3 09:18 knxultimatestorage
drwxr-xr-x    3 1000     1000          4096 Jun  9  2020 lib
drwxr-xr-x  104 1000     1000          4096 Jan  4 06:58 node_modules
-rw-r--r--    1 1000     1000         35864 Jan  4 06:58 package-lock.json
-rw-r--r--    1 1000     1000           827 Jan  4 06:58 package.json
-rw-r--r--    1 1000     1000         12450 Jun  9  2020 settings.js
bash-4.3# ^C
bash-4.3#
Isn't that where you should be running npm remove? Try removing it there.
If it isn't that then I think you need someone who knows more about docker to help.
It's just a warning - as they are in fact the same node (we renamed rbe to filter for 2.x) -the fact that they are overlapping won't cause an issue and can be ignored.
I have now executed the npm remove in the desired data-folder:
bash-5.0$ ls -la
total 432
drwxrwxr-x    6 node-red root          4096 Jan  4 11:48 .
drwxr-xr-x    1 root     root          4096 Jan  4 07:47 ..
-rw-r--r--    1 node-red node-red     16025 Oct 31  2020 .config.json
-rw-r--r--    1 node-red node-red     16121 Oct 31  2020 .config.json.backup
-rw-r--r--    1 node-red node-red     29589 Jan  4 08:03 .config.nodes.json
-rw-r--r--    1 node-red node-red     29662 Jan  4 08:03 .config.nodes.json.backup
-rw-r--r--    1 node-red node-red         2 Nov  1  2020 .config.projects.json
-rw-r--r--    1 node-red node-red        95 Nov  1  2020 .config.runtime.json
-rw-r--r--    1 node-red node-red       626 Jan  4 09:19 .config.users.json
-rw-r--r--    1 node-red node-red       626 Jan  4 09:19 .config.users.json.backup
-rw-r--r--    1 node-red node-red    116077 Jan  4 11:48 .flows.json.backup
-rw-r--r--    1 node-red node-red       152 Jan  4 07:29 .flows_cred.json.backup
drwxr-xr-x    4 node-red node-red      4096 Jan  4 07:58 .npm
-rw-r--r--    1 node-red node-red    116077 Jan  4 11:48 flows.json
-rw-r--r--    1 node-red node-red       124 Jan  4 07:29 flows_cred.json
drwxr-xr-x    3 node-red node-red      4096 Sep  3 11:18 knxultimatestorage
drwxr-xr-x    3 node-red node-red      4096 Jun  9  2020 lib
drwxr-xr-x  104 node-red node-red      4096 Jan  4 07:58 node_modules
-rw-r--r--    1 node-red node-red     35864 Jan  4 07:58 package-lock.json
-rw-r--r--    1 node-red node-red       827 Jan  4 07:58 package.json
-rw-r--r--    1 node-red node-red     12450 Jun  9  2020 settings.js
removed 1 package and audited 103 packages in 22.841s
1 package is looking for funding
found 2 high severity vulnerabilities
  run `npm audit fix` to fix them, or `npm audit` for details
bash-5.0$
After restarting NodeRED I have checked the webinterface again and now all nodes are changed to "filter" instead of "rbe". Thank you very much for your help.
The 2 vulnerabilites are from a S7-controller node, which I fixed with npm audit fix.
Thanks for your help Colin, now everything is fine.
