Update von Dashboard 1 auf Dashboard 2
Wie würde man am besten ein Dashboard von Version 1 auf Version 2 verschieben bzw. kann ich meine Flows einfach kopieren ?
Was muss ich beachten wenn es einen mobilen Nutzer von extern gibt der auf das Dashboard zugreift ?
Wie hoch ist der Zeitaufwand ?
Ich gebe Dir einen Tipp: Fange langsam mit dem Umbau an und betreibe zunächst beide Dashboards parallel (ist kein Problem). Und wenn der Umzug dann komplett abgeschlossen ist, kannst Du Dashboard 1 vollständig entfernen... Ist sicherlich kein 1-Tages-Job. Mach ganz entspannt (mir hat es Spaß gemacht).
As a hint: Start the migration slowly and run both dashboards in parallel at first (works perfectly). Once the transition is fully completed, you can completely remove Dashboard 1. It's not a one day job. Take your time (I actually enjoyed that).
That page was last updated on 02/07/2024, 11:40
Does it need a refresh or checking over to see if anything has been changed?
The migration process would not change I suppose, of course advancements would be there in DB2
My recommendation is to migrate on your own w/o using the service. While it takes longer, it helps understanding the (slightly) deviating concept of the individual nodes. And especially in my case, it has awakened the creative region with ending up with a much more beautiful dashboard 2.0 if compared to the old dashboard 1.0. The only problem you might experience with the new dashboard 2.0 is actually the chart node (which became a system killer with even a smaller number of plots). However, the nodered team is working on that with an alternative approach. But don't know when this will be available.
