Upgrade node-red on windows
Hi all!
I'm trying to upgrade node-red on my windows 10 from 2.2.1 to the newer.
So, I used the command
npm install -g --unsafe-perm node-red
as read in the guide.
After a few seconds, it returns
changed 293 packages in 14s
41 packages are looking for funding
   run npm fund for details
so I use
node-red
command again but it is still at 2.2.1 version.
I tried to upgrade NodeJs downloading from the website and now I have 20.3.0 version, but it seems that node-red doesn't want to upgrade anyway.
What I'm wrong?
Thank you all!
Hi, did you run your command
with version 20 of NodeJS or the previous version?
Hi @GogoVega
With both but nothing changed
Do you read the version of Node-RED from the terminal or from the editor (browser) because you have to refresh the editor. Do you get an error when launching NR?
Do you have v20.3.0 when you run the command node -v?
I read the number 2.2.1 from terminal and in browser too.
Yes, if I run the command you said it returns
v20.3.0
I attach what I see when run node-red command
PS C:\Users\Nu!Reha> node-red
12 Jun 14:41:03 - [info]
Welcome to Node-RED
12 Jun 14:41:03 - [info] Node-RED version: v2.2.1
12 Jun 14:41:03 - [info] Node.js  version: v20.3.0
12 Jun 14:41:03 - [info] Windows_NT 10.0.19045 x64 LE
12 Jun 14:41:04 - [info] Loading palette nodes
12 Jun 14:41:05 - [warn] [node-red-contrib-tuya-smart-device] Node module cannot be loaded on this version. Requires: >=2.5.0
12 Jun 14:41:06 - [info] Dashboard version 3.5.0 started at /ui
12 Jun 14:41:06 - [info] Settings file  : C:\Users\Nu!Reha\.node-red\settings.js
12 Jun 14:41:06 - [info] Context store  : 'default' [module=memory]
12 Jun 14:41:06 - [info] User directory : /home/nol/.node-red/
12 Jun 14:41:06 - [warn] Projects disabled : editorTheme.projects.enabled=false
12 Jun 14:41:06 - [info] Flows file     : \home\nol\.node-red\flows.json
12 Jun 14:41:06 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
12 Jun 14:41:06 - [info] Starting flows
12 Jun 14:41:06 - [info] Started flows
12 Jun 14:41:06 - [info] [alexa-remote-account:e66d9d76ee78d58e] intialising with the PROXY method and saved data...
And this is in the editor:
Can you run
npm list -g
If the Node-RED version is 3, can you try restarting your computer
Running the command it returns:
PS C:\Users\Nu!Reha> npm list -g
C:\ProgramData\npmglobal
+-- @tuyapi/cli@1.18.3
+-- node-gyp@8.4.1
+-- node-red@3.0.2
`-- npm@9.7.1
I tried to restart my computer but nothing changed.
When I run
node-red
command it says that I'm still at v2.2.1
can you delete this settings file (so that a new v3 format settings file is auto generated).
  • Stop node red
  • delete C:\Users\Nu!Reha\.node-red\settings.js (or rename it / move it)
  • start node-red
  • show us the output of the startup log
Laslty, what does where node-red reveal?
Hi @Steve-Mcl
I have done what you said and this is the startup log
12 Jun 15:39:40 - [info]
Welcome to Node-RED
12 Jun 15:39:40 - [info] Node-RED version: v2.2.1
12 Jun 15:39:40 - [info] Node.js  version: v20.3.0
12 Jun 15:39:40 - [info] Windows_NT 10.0.19045 x64 LE
12 Jun 15:39:40 - [info] Loading palette nodes
12 Jun 15:39:41 - [info] Settings file  : C:\Users\Nu!Reha\.node-red\settings.js
12 Jun 15:39:41 - [info] Context store  : 'default' [module=memory]
12 Jun 15:39:41 - [info] User directory : \Users\Nu!Reha\.node-red
12 Jun 15:39:41 - [warn] Projects disabled : editorTheme.projects.enabled=false
12 Jun 15:39:41 - [info] Flows file     : \Users\Nu!Reha\.node-red\flows.json
12 Jun 15:39:41 - [info] Creating new flow file
your credentials.
12 Jun 15:39:41 - [info] Server now running at http://127.0.0.1:1880/
12 Jun 15:39:41 - [info] Starting flows
12 Jun 15:39:41 - [info] Started flows
Now I have not my flows no more, there is nothing :sweat_smile:
Then if I use the command
where node-red
I obtain nothing
PS C:\Users\Nu!Reha> where node-red
because you had some copy paste code in your original settings
Your flows are in c:\home\nol\.node-red
Can you do that in a cmd window.
Also, please show me the content of c:\home\nol\.node-red (top level only)
Ok, they're safe :rofl: thanks!
Using where node-red in cmd it returns
C:\Users\Nu!Reha\AppData\Roaming\npm\node-red
C:\Users\Nu!Reha\AppData\Roaming\npm\node-red.cmd
This is what I have in c:\home\nol\.node-red
I guess now you need to modify the shortcut (C:\Users\Nu!Reha\AppData\Roaming\npm\node-red) to point to C:\Users\Nu!Reha\.node-red\red.js.
For existing files/folders in this folder you can move them to C:\Users\Nu!Reha\.node-red but first let's ask @Steve-Mcl if it's correct
EDIT: I don't know where the Node-RED binary file is located on Windows :thinking:
How can I do this?
Anyway, I have not any red.js file in C:\Users\Nu!Reha\.node-red
Ok so the Node-RED module is stored at C:\Users\Nu!Reha\AppData\Roaming\npm\node_modules\node-red.
This folder also contains a settings file: is userDir commented?
The package.json should show 3.0.2 as the version
Yes, userDir is commented.
The package.json in C:\Users\Nu!Reha\AppData\Roaming\npm\node_modules\node-red show this:
"name": "node-red",
    "version": "2.2.1",
    "description": "Low-code programming for event-driven applications",
    "homepage": "http://nodered.org",
    "license": "Apache-2.0",
(these are the 5 first lines)
:doh: I missed that!
Due to semantic versioning, you are simply re-installing the same version of node-red
Do the upgrade once more, but specify latest (or next if you want the cutting edge stuff)
npm install -g --unsafe-perm node-red@latest
or
npm install -g --unsafe-perm node-red@next
:scream: one more thing learned :heart_eyes: thanks :kissing_heart:
Nothing. :smiling_face_with_tear: :unamused:
I tried both commands in cmd and in Powershell too but nothing happens.
Just this
PS C:\Users\Nu!Reha> npm -g --unsafenpm install -g --unsafe-perm node-red@latest
added 6 packages, removed 12 packages, and changed 287 packages in 8s
  run `npm fund` for details
And
PS C:\Users\Nu!Reha> npm -g --unsafenpm install -g --unsafe-perm node-red@next
added 12 packages, removed 6 packages, and changed 287 packages in 19s
42 packages are looking for funding
but when i run node-red it returns
12 Jun 18:33:36 - [info]
Welcome to Node-RED
12 Jun 18:33:36 - [info] Node-RED version: v2.2.1
12 Jun 18:33:36 - [info] Node.js  version: v20.3.0
12 Jun 18:33:36 - [info] Windows_NT 10.0.19045 x64 LE
12 Jun 18:33:38 - [info] Loading palette nodes
etc.
Can you run
npm root -g
next is "beta" version and latest is "stable" version
PS C:\Users\Nu!Reha> npm root -g
C:\ProgramData\npmglobal\node_modules
