Node-RED is installed on Pi with the standard script :
Is it possible to update a node such as Dashboard with npm at ".node-red" directory?
The node was installed from the admin panel, but user may not access the admin panel unless modifying "settings.js" file.
Yes, just run npm update <pkg> in .node-red directory.
Tested but it did not work? Used the following command:
npm update node-red-dashboard
Dashboard was version 3.4. Restarted Node-RED after the command, but the admin panel still shows the old version 3.4. The latest version is 3.5.
npm install node-red-dashboard@latest
It depends on the semantic versioning defined in the package.json, to make it simple the following command will update your package to the latest version npm install <pkg>@latest. See here
Yes npm install works perfectly. To be safe, use the following command to update the node to a specific version (in case that future updates break anything). For example:
npm install node-red-dashboard@3.5.0
