Vehicle electric charger
Hello everyone,
I would like to know if any of these two electric vehicle chargers can be managed from the red node... where can I look at it?
WallBox Pulsar Plus 7.4kW Single Phase (5m)
V2C Trydan TRY32-1-L5 7.4kW Single Phase
I successfully control my wall charger using the OCPP v1.6 JSON protocol using node-red-contrib-ocpp
If your device supports the newer OCPP v2, you might wish to use node-red-contrib-ocpp2
I don't understand what you are telling me, I have these two inverters to buy and I don't know which one to buy, since I want to command them from node-network.
A quick internet search shows that this one at least does have ocpp. I didn't check the other (I don't have either of these).
I am saying
So if "WallBox Pulsar Plus" OR "V2C Trydan TRY32-1-L5" supports OCCP v1.6, then node-red-contrib-ocpp should work for you.
Additionally, If either of them support OCCP V2.x then node-red-contrib-ocpp2 might work (I haven't tried it)
Not certain how much clearer I can be?
ok, I understand, thank you very much for your quick answers.
