Vertical layout problem with ui-linear level indicator
Hello everyone, I install ui-lineer level indicator in dashboard node-red. When I use it horizontally there is no problem but when I choose vertical layout I can see value label but I cannot see bar segments in color I set. They are seen in off color all the time in vertical layout. What might be the problem ?Ekran Alıntısı
Thanks for reporting, will be fixed later today.
Fixed in v0.1.29
Thanks for your interest :slight_smile:
