Waiting for missing types to be registered: [info] - graph
HI, I try to import a flow Embed Grafana Chart in NR dashboard I it show a message unknown node Graph, y try to delete but I couldn't I try to delete the flow and was not possible to delete. So I restart and now is stopping, here is was is showing in CMD..
13 May 18:49:01 - [info] Node-RED version: v3.1.3
13 May 18:49:01 - [info] Node.js version: v20.10.0
13 May 18:49:01 - [info] Windows_NT 10.0.22631 x64 LE
13 May 18:49:03 - [info] Loading palette nodes
13 May 18:49:08 - [info] Dashboard version 3.6.5 started at /ui
13 May 18:49:09 - [info] Settings file : C:\Users\OBS.node-red\settings.js
13 May 18:49:09 - [info] Context store : 'default' [module=memory]
13 May 18:49:09 - [info] User directory : \Users\OBS.node-red
13 May 18:49:09 - [warn] Projects disabled : editorTheme.projects.enabled=false
13 May 18:49:09 - [info] Flows file : \Users\OBS.node-red\flows.json
13 May 18:49:09 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
13 May 18:49:09 - [info] Waiting for missing types to be registered:
13 May 18:49:09 - [info] - graph
13 May 18:49:39 - [info] Stopping flows
13 May 18:49:39 - [info] Stopped flows
Please i Look around but found some info but not direct l=related to fix this, Please anyone that guide me to resolve this problem
What happens when you try to delete the flow you imported?
Thanks I FIX I. I delete the flow in the dir and use the backup and is up and running
.Thanks you as always for yout time
