Is there a file location where the NR projects are stored? I want to copy it and save as a backup.
I messed up my Pi before backing it up. I'm unable to network into it. So now I have to hookup the SD card to my PC, and sift through the folders. But where is it stored?
You don't need the node_modules folder that you will find there though, that is very large, and is easily rebuilt after restoring the rest of the folder, by running npm install in that folder.
Normally if I work in NR, go to export flows, I can export the flow 1 at a time. I have 4 flows in my project.
But here, it seems all the flows are combined into 1 json. And if I move that above file into a new build, I should get all my flows back? Provided all my modules are installed of course.
If you have installed any additional modules then also copying package.json and package-lock.json will avoid you having to re-install those one at a time, and if you have changed anything in settings.js then you would need that too, plus any static files and so on that you may have added. The safest thing is to transfer the whole of the .node-red folder except node_modules and then run npm install to install any additional nodes you may have used.
