Why..... [error] [Barcode Decoder:Qrdecode] NotFoundException: No MultiFormat Readers were able to detect the code
[{"id":"9d026d51.1a392","type":"tab","label":"webcam+Qrdecode","disabled":false,"info":""},{"id":"5e606e13.97f31","type":"inject","z":"9d026d51.1a392","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"data:image/png;base64,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","payloadType":"str","x":170,"y":120,"wires":[["4c21d07e.1f1e6"]]},{"id":"4c21d07e.1f1e6","type":"ui_webcam","z":"9d026d51.1a392","name":"","group":"e9f847cb.043ce8","order":5,"width":0,"height":5,"countdown":false,"autoStart":false,"hideCaptureButton":false,"showImage":"2","mirror":true,"format":"png","x":340,"y":120,"wires":[["a5dcaa03.6c6a88"]]},{"id":"a5dcaa03.6c6a88","type":"image viewer","z":"9d026d51.1a392","name":"","width":"160","data":"payload","dataType":"msg","x":510,"y":120,"wires":[["48bfbb63.81e304"]]},{"id":"48bfbb63.81e304","type":"Barcode Decoder","z":"9d026d51.1a392","name":"Qrdecode","data":"payload","dataType":"msg","tryharder":"true","tryharderType":"bool","QR_CODE":true,"DATA_MATRIX":true,"PDF_417":true,"EAN_8":false,"EAN_13":false,"CODE_39":false,"CODE_128":false,"ITF":false,"RSS_14":false,"x":700,"y":120,"wires":[["6bb5b15e.53c7e"]]},{"id":"6bb5b15e.53c7e","type":"debug","z":"9d026d51.1a392","name":"read","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":910,"y":120,"wires":},{"id":"e9f847cb.043ce8","type":"ui_group","name":"Display","tab":"b7832925.cf1fc8","order":4,"disp":true,"width":"6","collapse":false},{"id":"b7832925.cf1fc8","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Hi, in order to make code more readable and importable it is important to surround your code with three backticks
like this
You can edit and correct your post by clicking the pencil icon.
Also tell us which node you are using, node-red-contrib-something probably.
unfortunately the decoder in "image-tools" is not the greatest & needs better imagery than you have provided. You might be able to use the various "image tools" functions (like crop, contrast, brightness, rotation, re-sample, slight gaussian blur etc) to make it readable before sendinr to the decoder
That said, to prove it is actually working on your system (and it s not something else), import the demo (CTRL+I --> examples)
Do the demos work?
*the Qrcode that i decode i took it from a webcam camera shoot
