Barcode from android camera
Any solution in nodered to read barcode or qrcode from smartphone (android) camera?
In particular: https://flows.nodered.org/node/node-red-contrib-image-tools
Barcode decoding...
barcode-decoding
How to take pic from smartpone cam? "node-red-node-ui-webcam" node not working
In what way?
As per the readme:
Browser Support
This node will work in all modern browsers, but not IE.
If you are accessing the dashboard remotely (not via localhost), then you must use HTTPS otherwise the browser will block access to the webcam.
Are you using HTTPS?
