I am trying to install nodes and when I open node-red the log says that npm could not be found
open a terminal window.
Enter the following commands and show what you see...
npm -vnode -v
PS: as the text says, you need NPM installed to use the library. Also, this has been covered many times on the forum (do a search)
For my node version I have v12.16.3 and for my npm version I have 6.14.4
Odd - that version of NPM is sufficient.
How are you running node red (what command line do you use / how do you launch it)
Is it a direct install or docker?
what OS are you running on
also, post a copy of the terminal startup log (as text (not screenshot) if possible)
It is a direct install I am using windows and the line I am using is node-red
copy and paste the text that appears after entering node-red please
Paste it ...
like this - between three backticks (for formatting and readability purposes
Welcome to Node-RED
24 May 16:49:26 - [info] Node-RED version: v1.0.6
24 May 16:49:26 - [info] Node.js version: v12.16.3
24 May 16:49:26 - [info] Windows_NT 10.0.17763 x64 LE
24 May 16:49:26 - [info] Palette editor disabled : npm command not found
24 May 16:49:26 - [info] Loading palette nodes
24 May 16:49:28 - [info] Settings file : \Users\ethan\.node-red\settings.js
24 May 16:49:28 - [info] Context store : 'default' [module=memory]
24 May 16:49:28 - [info] User directory : \Users\ethan\.node-red
24 May 16:49:28 - [warn] Projects disabled : editorTheme.projects.enabled=false
24 May 16:49:28 - [info] Flows file : \Users\ethan\.node-red\flows_LAPTOP-N2EBLI75.json
24 May 16:49:28 - [info] Creating new flow file
your credentials.
24 May 16:49:28 - [info] Starting flows
24 May 16:49:28 - [info] Started flows
24 May 16:49:28 - [info] Server now running at http://127.0.0.1:1880/
That is most likely the answer I just need to look to where the path is
This is where the folder npm is C:\Program Files\nodejs\node_modules\npm OI do not know if this is true or I am looking at the wrong file
what do you get if you enter where npm in a cmd window?
I get Nothing when I put where npm
sorry typo. try which npm
Which Give me an error saying that it isn't a command
then your'e gonna have to search you computer to find NPM.
Its likely to be in C:\Program Files\nodejs\node_modules\npm\bin - have a look see if npm.cmd is there.
When you find the path, add it to the system path, restart the CMD window, type path to check its present then run node-red.
now node red will not start
Did you add or change path?
Edit...
Potentially, node red wasn't in your system path either (and your command window was on the right path to start it)
Basically speaking - the application your are trying to start MUST be on the current path OR in user PATH or SYSTEM PATH.
For node-red to work properly, 3 elements have to be reachable...
- Node
- npm
- Node-red
ok I will try to make it work
What if I uninstall and reinstall Node.Js and Node-Red and see if I can run it again?
Possibly but a bit overkill.
Better off fixing it then you'd learn something. But if you must...
